SkwurlyFab
AT full volume my speakers will cut out and the sub will keep playing. I know this is horrible for the speakers and amp so I need to fix it.
Neither of the amps go into protect when this happens.
BTW the sub amp is one of the new orion 5000's running at 1 ohm and the component amp is a JL 300/4.
Sometimes it will play at full volume for a while and then cut out, sometiems I will turn it up and it will cut out immediately. Only the component amp though, never the sub amp. And obvoiusly some songs are worse then others depending on how much bass there is because it seems to me like the sub amp is ******* up all the power and not letting the component amp have any.
But it's weird though because even when it cuts out my battery still reads in the 12's and so does the power inputs on the 300/4. The only thing that drops in voltage is the outputs on the 300/4 that run to the speakers, yet the amp is still getting a full 12+ volts.
I have an upgraded alt and a yellow top under the hood. I have 2 runs of 0ga running to the back of my 4runner, 1 power and 1 ground. I don't have the amps grounded in the back anywhere, the grounds just run to a distro which runs back to the yellow top through the 0 ga cable. I have also done the big 3 in 0 ga.
So what the hell could be the problem here? I also have horrible dimming still and that's with an alternator, yellow top, big 3, 0 ga wiring, and only 2 ****ing amplifiers. So what's the deal? Any help would be appreciated let me know what ya got!
