yes do the big three, no voltage will drop some, look into a better alternator, then battery later on if needed.why 4 12???
in the right encloser you can make those 2 subs flex you car.
maybe if you where to fibre glass that plywood,but plywood sucks even on 500 to 1000 watts,
birch or mdf or any really dense wood or fibre glass will work.
is your amp bridged???
is your trunk deaden???
you need some room for the air from the port to flow.
i which i could hear it in real life.
which it seems you aready know that!
buy what then about your front stage???
do you have good comps up front???
those subs with the right amount of power will out drown your front stage.
I can help you with the head unit install, other than that I ran the wires under my car because I didn't want to drill through the firewall.Trunk is really large, not sure the most you could fit in there though. I have a 94 LeSabre, same color, got any install pictures? I'm about to install and have no experience with an install in this car.
It should have been a spot on the firewall to run the power wire through somewhere near where the steering wheel goes through it. Took me a while to find it on mine, ( I use to own a 93 Lesabre).I can help you with the head unit install, other than that I ran the wires under my car because I didn't want to drill through the firewall.
yea its w/e. Thats the only cd I had in my car. i took my mp4 player inside.close enough lol.
lol, type r's are "good" low budget sub. I dont want two 300 dollar a piece woofer...build a MDF box, i wouldn't go 4 12's just sell the Type R's and pick up a couple good 12"s here in the classifieds.
what part of Indiana are you?
saz-1500D or pre order a new saz-2000Dlol, type r's are "good" low budget sub. I dont want two 300 dollar a piece woofer...
However, when i pick up some MDF I am going to try a sealed and a ported box on my new amp, and see which sounds louder.
I have no Idea what kind of amp I am going to get though. probably something that does around 1200 at 2 ohms.
Maybe the kicker 1000.1
