My first real setup!
Middlesex County
I work at a detail shop, so car's usually clean. Although, right now, it has a big dent in it because my friend hit me. Even though my car was PARKED at my house at the time. He still managed to back into me.
could you take a real close up pic of your RE tweet, im thinkin about getting them, but havent seen them yet
also how do you like your RE components
nice ride/setup!!!
nice ride/setup!!!
I'll get you a picture tomorrow. The components are alright, but def. needed to be amp'd. Specially now with the sub and everything in
Excuse my idiocy, but how do I know if I'm maxing my sub out? Sub-W is set it 8, bass is set to 0.
and the amp is set to
gain = little bit more then half
freq = 30hz
is that okay? i don't want to kill my sub.
freq = 30hz
use #3 to set your gains http://www.resnet.trinity.edu/areynol1/gain.htm
realm has test tones under "downloads" http://www.realmofexcursion.com/main.html
lpf = low pass filter = lets low frequencies pass so the subs produces them
hpf = high pass filter = lets the high frequencies pass so your speaker can produce them
this is what crossovers do, they control what frequencies a speaker will play
subsonic filter/crossover prevents a sub from playin too low of frequencies
most set their lpf to around 80hz, hpf to 80hz and subsonic filter around 20hz
its mainly what sounds good to you
if youre using a sealed box for your subwoofer, you dont need to use a subsonic filter
i guess either way, you dont HAVE to use one, im using a ported box without a subsonic filter
//content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
kevin85193
boost?
kevin85193
NJ
JCivicHb
