my first box build/s
Well to make it bigger we would have to increase one of the dimensions. So far the outside dimensions are going to be at your max 32.5 * 16.5 * 15.5.
31 * 15 * 14 + 1.5 to all sides
32.5 * 16.5 * 15.5
Which dimension could you give a little more on?
Well seeing as how the box is 1.6 cuft with your max dimensions you are going to have to go out and measure your car to see if we can squeeze some more out of it.
ok, so the plan for the 12" rl-ps sealed will be 31.5 x 16.5 x 15.5 externally. 1 inch shorter than my max dimensions i posted. this is all including the divider/bracing/displacement. it comes out to 1.52^3 each. maybe use some polyfill to take off that .02^3
give me a few to work on the box for the 12" brahmas.
ixnay on the polyfill my brother. Polyfill makes the enclosure seem larger. It's gonna be sealed I wouldn't worry about .02 cuft. You won't notice it. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
yeah. after amr92 gave me his dimensions, i wasn't worried about it. i'll go either way with it then.
as for the measurements i'll be right back with the true dimensions.
Well, I am taking my fiance to lunch so if ramos cant help you on your final dimensions for the Brama I will as soon as I get back. If you need any more help just post in here or pm me I will be glad to help. Have fun.
Remeber Measure 4 times cut once. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
so i redid all my calculations.
for the RL-P's:
30.75*14.75*13.75=6236.48/1728=3.60-.36(displacement of both drivers)=3.24/2=1.62-.13(divider and bracing values combined)=1.49^3
for the Brahma's:
30.75*15.25*14.25=6791.01/1728=3.92-.3(displacement of both drivers)=3.62/2=1.81-.13(divider and bracing values combined)=1.68
am i correct? does anyone see any problems/have any suggestions?
dkguitarist
dkguitarist
Oklahoma City, Oklahoma, United States
amr952
vegang
vegang
