My Final Install (feel free to Flame) 56k Warning
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif No such thing as a final install.
As for your lights dimming, make sure your amp is grounded to a nice, solid, shiny piece of the body.
are u running it at 4 ohms bridged? and did u set ur gains?
Let me say something before I tell you what Ohms in runing on, I don't understand anything when it comes to watts ohms or voltaje I'm a brand new rookie, that said I just call my tech and he said is set up on 2 omhs .... is that Info right?
Read.
Good install, nice pictures. Looks great for a rookie.
That amp is the perfect power for that sub.
If your happy, that's all that matter.
Doesn't matter what other people think.
Thanks Kicker guys, I apreciated your comments
Your sub is DVC 2ohms. So you can have either 4ohms wired in series. Or 1ohm wired in parallel.
Read.
agreed but take that amp down from there
IF that doesn't work? just asking
It's a two channel amplifier, so it could be wired one coil per channel...
Not too bad for a first timer. Sounds like you need to pick up some reading on a 12v system, and Ohm's law //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
amps mounted poorly.
box probably not bolted down?
need correct dash kit for HU.
and the fuse holder under hood is not properly mounted down.
you need some fixin.
Thanks for your comments I apreciate you taking your time to review my install, will fix according to your demands , thanks
regarding the amp mount is because is upside down right?
Is necesary to bolt the box?
Octavio
Octavio
Nic
moh.vze.com
