My ears hurt :D
kickerlivinloud
Banning survivor
Well as most of you know I had just installed my LI last week. It was in 3.7 @ 28Hz. It wanged nice and sounded unreally good BUT, I knew that the box wouldn't be loud enough to satisfy by bass head fevor so I also built a 2.5 @ 45Hz. OMG WOW!!!!! This thing is so loud now!!!! After sitting in it for about a min on a couple test tracks my ears were hurting so bad, I had to stop. There was a very noticible difference in loudness just by ear, let alone what i mic would tell. The air flow I now have out of the port is 2x if not 3x more then I had with the other box. My new box has 48^2in of port compared to 28^2 or so. My car also rattles even more worse then before. If anyone out there says that the tuning of a box has no effect on the output i dare you to come and sit in my car and let me swap out my boxes. I'm still blowen away at the output this new box has. Looks like I'll have to give my buddies 2 L7's another run.....heheheh //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Just thought I would share my joy with everyone else. I will get some pics and even maybe a vid some time //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Jon
Actully I didn't listen to it for that long. I did notice a little bit of loss in the SQ. The sub was also over powering my fronts so it was hard to tell. I will write more tomorrow after I have had a little more time to listen to them. The fact is plan and simple, it was so loud it was quite hard to tell. Like I said, I will reply with more info later tomorrow after school...
and with some pics as well...//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Jon
Ok, I had more time today to listen and was impressed by how much worse they DIDN'T sound. I mean ya there was a difference in the SQ of it but I figured it would be really bad, but it wasn't as bad as I thought. Like I said before, deffenitly hits much harder. Really happy with both boxes, the only problem is that they are a pain in the butt to swap. This box isn't as bad but that other one wieghts close to 80-100lbs probably. It also is a tighter fit in the trunk. So pretty much its this, even at 45Hz I was still able to maintain fair SQ which come to a total suprise to me...
Jon
Good job kickerlivinloud... real glad you like your setup after your immense patience. //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
nothing against anyone...
Alot of people like slightly peaky sub installs. Wether it's cause that's what they're used to, the musical stylings, or just cause their opinion. Nothing wrong with you're tuning cause You're listening to it. LoL
I personally dont tune my sub enclosures under 32-34 (pending driver). I like a lil lump in my daily //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
How would you rate that A8000T? I was going to use it in my setup, but settled on a Hifonics BX1000D instead... I sold the A8000T to my friend who is gonna use it to power a nice Memphis sub, we'll see how it turns out..
I would rate it pretty good. This is my first install so I have nothign to compare it to. All the other installs my buddies had were of far smaller wattage and far lesser quality so it was my first dive into a "decent" amp. I have had no problems with it other then it does get a little warm but i guess that is to be expected, other then that, even though its bling it puts out the power...
Jon
kickerlivinloud
Banning survivor
kickerlivinloud
Finger Lakes, NY
kickerlivinloud
