My Custom Box Design using WinISD - Will it work?
I'mPoor:(
SoundQubed Is Life.
So here is my box plans for those of you who can read it
Here is the WINISD info based on my subs and the port I chose
http://i.imgur.com/HxvveuW.png
http://i.imgur.com/3fACvgm.png
I am making the box now, so any quick input would be great. Those plans are just a sketch too so not the actually sketch I am going by. Dimensions are correct though.
Thanks!
I didnt know what those were. Notches it makes sense now that explains why our calculations are slightly off Your math looks good and your port size is good.
imgur: the simple image sharer
So I was sleepy and we put the Top on backwards(we plan on remaking it), idk if it makes a difference. In currently waiting on my seconds hds312 to ship. But I turned it on and played it and holy Crap. It's louder now then with my other box. Even with just one in it!!
I have a HDS312 build scheduled to start on Thursday we will be using 5.8 ^ft. Bass Box Pro suggests 3.8^ft per sub but trunk space has maxed our size to 5.8^ft.
Yeah my trunk area is literally maxed out with this box. I left 5-6 inches for the port to breathe but that is it.
Not sure what you mean but volume is volume now air flow being restricted can cause problems but your box is spacious enough inside for the air to circulate.
Okay, so you don't see anything wrong with how my subs are going to bepositioned now? Air movement wise. If not I will double baffle like it is
I'mPoor:(
SoundQubed Is Life.
I'mPoor:(
Gadsden, Alabama
I'mPoor:(
