My amps wont turn on *extremely frustrated*
flakko
Veteran (my butt)
i dont get it. i was doin an install on my friends car and the speakers werent working. I decided to take my eD9.2 out of the car and and switch the pg out to see if i hooked everything up correctly. Everything was fine. Now here is the problem. Once i put everything back in to my car and hooked everything up, i found out that both my amps wouldnt turn on. i checked the fuses, all fine, all the connections, fine also. the HU works.... but it seems that my amps wont turn on. What the heck happened?
oaky my friend found something else out, when i turn the stereo on, the protect light in only the 9.2 turns on for some time, and then goes off. but my viper does nothing.
ggrrr!!! i wanna kill someone rite now....
Something is not at piece with the wires, you must rearrange you're "fung shway" to get the proper balance of ying and yang.
I don't have a fvcking clue..LOL
was checking, and im like, theres power going through to the REM, but no power through the power wire.
wait !!! i figured it out! i dint check the battery fuse. it was blown. good thing i had a replacement. okay thanks for all yal input. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif i appreciate the fast response
flakko
Veteran (my butt)
flakko
So Cal
flakko
