my amp has no fuse??
johnnyblaz3
hey all i have a amp that does not have a fuse in it.. i was told i should put a fuse in it for safety.. now putting a fuse in the amp how should i do that.. should i get the same fuse holded i have by the battery and connect it to the power wire 18" from the amp? or do i gota get a smaller fuse for the amp? let me know thanks
ok well i have a 80a fuse up front and i have a 100a fuse layin around.. if it okay if i used that? uneven amp fuses,, is it better if i used 80a fuse to match it? and i geuss i just add the fuse close to the amp on the power wire correct?
yea, put the fuse a few inches from the amp, like no more than 6 or so. and use the 100. different size fuse ratings wont hurt anything.
Incorrect, there are fuse ratings for a reason. It's there to protect your equipment. You don't just through a 50A fuse on a 5,000w amp. You must fuse it according to the manufacturer as stated in the manual, just like wu501 mentioned.
your right, but i checked, and its a 1kw @ 2 ohm amp. i generalized 1kw to draw 100-120 amps, depending.
True, my PDX's requires 100A. Though some overrated amps will have less fusing, which won't be the issue with the Pioneer.
i dont think i have the manual... only the box... and im running 500w at 4ohms right now so do you know about what size fuse i should use?
I searched google and Pioneer's website came up. Clicked on support then user manuals, downloaded the English version and in the diagram it shows a 100A fuse just as blackdragon mentioned.
johnnyblaz3
johnnyblaz3
comp chair
johnnyblaz3
