My amp going into protect only second start.
I have a JX1000/1d and when ever I start my car it works fine green light and music bumpin.I turn the car off to take the bar off, turn it back on and its in protect and wont turn green unless I wait a long time. It only works first start up, I checked the ohms coming from the sub and its a steady 2.0 and also took all the wiring off the amp and put it back on, still nothing.
Really pissed off Iv checked everything I can think, anybody have this prob before?
sounds like you didn't tune your amp properly and its over heating . turn down your gain and see if it continues the same . Not saying you didn't but it is an option
Yeah I didn't tune it, I think It's down already but Il try.
If your voltage is 16 volts and your battery and alternator are 12volt then most likely your alternator is bad. I wouldn't run the vehicle as it may damage other components in the car.
That amp will run safely up to 15 volts.
I had an alternator do that once..I had to turn everything electrical on I could to keep the voltage down..Its the Internal Regulator in the alternator.Its bad..you need to replace it before you burn up the electrical,in the vehicle/wires/brain/ect!
wow i missed the 16 volts . He is pretty lucky that the brain if the car has one hasn't burnt out . that will cost your left nut to fix . OP i would suggest unhooking the alternator and getting it checked out . OR taking the car to auto zone or Advanced Auto and having them do a battery alternator test . they can tell you whats wrong with your alternator if anything is wrong for free
daveishome
daveishome
Canada
dbertoli
