My Amp And Subs, Are Hitting On There Own Free Will.
Op doesnt want help.
If you were such a genius you would know first off your power and ground have to match. You cant draw in 150 amps we'll say on the power wire and expect the 6 ga wire to disperse that same 150 amps through the ground. 2nd off get a solid piece of power wire before you start a fire.
and well after that just /yourself.
You need to research a bit more before you think your ghetto ass system is burping off a 155.xx
ported for the lows, sealed for the highs //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
n0ob
So wait, wait, wait....I been doing it wrong?? **** it, I was wondering why I just couldn't get it to sound right:(
No, no, no, no.
Ported for the SPL, sealed for the SQ. It's the best of both wolds - loud and quality. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Ohhhhh, I get it now, yeah....
My old powered sub was doing this exact thing; it was trying to pull ground from the RCAs. Ensure grounds are good and connect RCAs after, my $0.02. & Fix your power wire/ground situation right away.
and dude... listen to the people here. You will benefit from their advice.
A 4000w pyle amp huh? you know what that means....
2x 12 inch JLs - 1200 watts each. 4000 watt pyle amp. Ported box.1x 12 Inch Alpine - 500 watt. 1800 watt amp. Enclosed box.
4 Door speakers - All 6inch Sonys
2 front dash speakers, 4x6 Sonys
2x 6x9 Memphis speakers, boxed off and in the back of vehicle.
Been using all this for about 2 years now. Not the loudest around here, but no one can match my sound quality cause you can still hear the lyrics and feel the base with the volume up.
I am really tempted to sig this...hmm...
^^^what she said^^^ lol, go look up ampacity of the wire...google should show you a chart of awg/distance. now, there is also connection point resistance, especially when it's just 2 bare clusters of wire strands touching. though it does not matter, since the current has to flow the full run of the circuit (power amp ground) and should be matched, power actually flows from ground to positive. just food for thought there....... about the mis-matched subs and enclosures, there is a lot, way over your head, but simple paints are that there is cancellation going on, which is typical, and a reason you just don't do it. you will actually get the one taking volume away from the 2, and visa-versa at different frequencies, and end up with over-powering in others, just to start with..... the fact that you did not get laughed out of, or picked fun at when competing tells me that there is no shop, or, likely active entheusiast in the area that has half a clue, AND THAT INCLUDES EVERYONE AT THAT WANNA-BE SHOP!.....
so, to make things short here- there is 2 things- one, your grounds (and power for that matter) are insufficient, and more importantly, the lack of grounding is forcing the amps to accept current from the head unit via rca shielding, and it WILL blow your head unit, just a matter of time. the dry connection on your board (yes actual technical term for the condition of your rca solder) is giving you a thump because the amp can no longer pass decent current. going with your high level is just a fix of one thing, but does not fix an obvious problem...... and before you go talking ish about my systems, keep in mind i've built several that use the same size speaker wire as you have for ground. systems that stop a running engine, jump the wipers of the windshield over an inch, make it nearly impossible to breathe, much less see anything, and i know that it doesn't compare to what many have done on this site, likely members that have posted in your thread included. as for aptitude for car audio, well i have been repairing and upgrading amps and subs, aside form all the builds since the 90's. yes, i have been to school for electronics, and no, i will not advertise my equipment to you... you have been given good advise, which (oddly enough) you could even see for yourself before stating your thread. take it or leave it. good luck
maybe.......
oh, and how is this for sound quality- crisp, clean, decernable piercing mids/highs through double hearing protection..... to keep up with the subs that required the double hearing protection
this dude gotta be kidding lol.... his walmart specials are "loudest in the city"... i do hope he is serious tho cause this thread is really...really funny then.. i would LOVE to see the install in this car with the spliced wires everywhere lol.. get out your hot dogs and marshmallows boys theres gonna be a fire.
ZhadowZ
ZhadowZ
Wichita, KS
jtomsic
