my alpine skips a lot!!!!!!!
jeremythelen
i recently bought a used CDA-7840 alpine head unit and it skips all the time. its like a $450 (regular price) cd player and its pissin me off when it skips. from what i hear about alpine even if it is installed poorly it shouldnt skip. i do live on a dirt road that can get pretty rough but it skips a lot. sometimes it will stop playing for like upt to 10 seconds! it has 4ve preout if that means anything, im new to car audio. any help would be appreciate
One of my friends had that problem with his H/U so what we did was get a piece high density foam and place it under the H/U. It doesn't have to be big and you don't want it to cover any of the ventilation holes. It also might be worth checking if it is mounted properly.
Peace out,
Matt
I have the Alpine 7875 and it skips reall easy, i hate it, even if i crank up my **** my car vibrates so much it skips, i'm drivin down the road hit a lil bump, it skips, oh well, its probablly my install instead of the cd player itself
is it really stiff foam that you use or softer? and i pulled it apart the other day and it was loose. and the reason why it is loose is cuz my dash got warped from the sun so the pannel that goes over it doesnt fit very well. i toyed wiht it a little bit and got it a little bit tighter and it seems to be better. but i never did try the foam. i didnt feel like drivin anywhere to get it. and i drive a 93 cutlassupreme
the foam that you'll need is stiff. There is a range of places you can get it from. The bet bet would be to go to a rubber shop but failing that you can try the hardware store and if they don't have it they can tell you where to get it. Just ask for "High Density Foam" and they'll know what you mean. The peice that we cut was about 6cmX7cmX4cm but that was cut so that it didn't cover any cooling vents. You may not need it very thick, just play around with it and see what works the best.
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
118
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
368
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
jeremythelen
jeremythelen
Wesphalia,MI
bass_master
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
