My 1008a's in action.
The sound, over excursion. When you see my subs at full excursion during Late Night Tip, they're bottoming out, and you can hear the difference those notes are making.
I think you need another 1100D and strap them together at 2 ohm mono on the pair....Send an clean unclipped signal to them...your box needs to be shared chamber...two cuft...total....port needs to be 30 sq inches...I prefer slots...and 16" long.....I can't watch vids on dialup so I don't know what size box your running these in....but with that box I described for daily...you won't go wrong //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The box I have is 1.7Ft^3 separate chambers, each chamber has .7Ft.^3 tuned to I THINK 38-39Hz. I'm going to pick up some polyfill today, and see if they like it any better with about .5-1lbs.
It may work but multiples like shared chambers the best //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Now that is 1.7 total...not per chamber I hope....because you could run two 8's in 1.7 If per chamber that could explain bottoming....I've only owned about 40 DD 8's...So I know those subs inside and out.....I have had all series of 8's that DD has made that I know of even the double stacked 8's before the original 1008's....//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yes, that is 1.7 total, not per chamber. I'm building a new box whenever I get my tools back, this is just temp.
Try what I told you that will make you happy....//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif That box you have may be a little small for them as of yet....shared chamber it would of been closer to right...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
95BlackGA
95BlackGA
Missouri
Louisiana_CRX
