Dd 3515
abdulwq
Hi guys
I was just wondering that is it possible to power DD 3515 dual 4ohm to 2 Alpine Mrv 1505s?
I mean i bridge each amp to power each coil of the sub.
Would you guys recommend a slot ported box for the sub or Whats?
Pls help and any suggestions will be appreciated.
Cheers
RMS rated Power at 12 volts
150x 2chanels at 4ohm
600 x 1 chanel bridged at 4ohms
RMS rated Power at 14 volts
225x 2chanels at 4ohm
900 x 1 chanel bridged at 4ohms.
a lot of reviews say that it is under rated power.These amps were the last generarion made in japan.
You will be fine with 1200 watts, but honestly, it could take 800-1000 more. Just know you can always add more power if you don't like how it will sound with those 2 amps.
He would be feeding it more like 1800WRMS, you were looking at the specs for 12v. All I have to recommend, is that you better make sure you set the gains perfectly matched with each other.
abdulwq
abdulwq
Tampere Finland
95BlackGA
