multiple runs and multiple batts
Gianotti
UNLIMTED POWER
i have searched, but couldnt find the anwser i wanted, i have 4 + and 4 - of 0 gauge runs and 4 yellowtops inside my truck, when i wire them up, would i run all the leads off the batt under my hood to the 1st batt in the back and then go + to + to + to +and - to - to - to - to - from batt to batt. and i know about the fuses to i have that done already. help me out ASAP!!
Holy crap, that's a lot of wire.
Anyway, if I understand you correctly, you want to run all four runs to a single battery in the back, and then take a single run of 1/0 and jumper the batteries together? Seems like that single run of 1/0 between batteries would be a bottleneck.
Sounds better to run each of the four cables to each of the batteries. i.e. One run from the front battery to battery #1 in the back, run #2 from the front battery to battery#2 in the back, etc. Then from there, you would still have 4 runs to connect to your amps, for even power distribution over all 4 runs.
yeah thats the way I have my 2 batteries with 2 runs connected
It would also depend upon how long the runs between batteries would be. Batteries all in a row the runs connecting them would probably be 12" or less, so it might not make much of a diff, but if you have enough 1/0 to do 4 runs I'd wire them as suggest above...
ok let me get my self straight here. after all 8 (power & ground) runs from batt under the hood to batt 1 in back, jump 4 leads of power and ground from batt 1 in back to batt 2 in back then same thing with batt 3 and 4? or am i wrong? if so could someone draw me a diagram.
Gianotti
UNLIMTED POWER
Gianotti
ceciltuckey, Md
tapout
michigan born
    May 14, 2026
michigan born
    May 14, 2026
