Multiple amplifiers on stock headunit?
kjearl
What would be the best way to run multiple amplifiers on a stock head unit? I want to run an amp to all four speakers, two tweeters, and maybe add a sub. I want to keep the stock head unit to maintain a factory look.
Many OEM interfaces will use as few as 2 channels of input and then create additional channels of output. Audio Control products can do this, as well as any of the big name 8-channel DSPs.
IF I was ever going to run a stock HU, I'd go with the JBL MS-8... Anything less than a DSP and you're basically just running a glorified line out converter... But depending on your goals here that may be enough to make you happy //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif GL with whatever you end up doing //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
What is the difference between the signal out of the PAC and something like the LC8i?
I don't know too much about OE signals.
The best answer is to read up on both. I have used both, but the LC8i will offer a far superior signal and performance. There are some great write ups on Audio Control and their products.
I was looking at them to do just that, but I'm not exactly sure what I'm looking for. The have a bunch of different stuff. I just wanted a clean signal out.
But I digress. - sorry to threadjack
kjearl
kjearl
NoVA
dragwindsor
