Multimeters and clamp meter
  • 6
i figured these would need a lot of electrical but thats just absurd lol i mean maybe not since you dont have voltage drop but you built it up similar to what people do for 2 korean 8-10k's
if you get the opportunity to put a dc clamp meter on it and somehow get an "accurate" current number even if split among runs id be interested. for some reason i expected under 1000a of draw
1000 amps is not even enough to make rated power ....1200 amps at 14.0v at say 80% efficiency is still just 13440 watts ..... 1500 amps @ 13.8v @ 76% is just 15732 watts ..... it would take at least 1200 amps @ 90% @ 14.4v to make just over rated power = 15552 watts rms ...
if that amp could produce those numbers then im way out of my league because in the future im only considering ~8-10k but im saying this with a margin of error for brazilians with rise. 1000a is a lot for any build. anyways its given me more information on the bass 15k and thats what i was after
if a clamp is around, just let me know what it draws... i was surprised to see numbers lower than i expected and want to see how this one does.. rise is a killer and savior with these amps
Your not going to find anything past a 1kamps. You going to need cts or current transformers..
im betting itll be less than that and if anything one or two wires at a time because obviously there will be multiple runs at this amount of current
ive got a fluke dc clamp meter and it seems to be pretty accurate i just hate how expensive they are
Thats easy clamp each wire and add.. lol
Biggest wire ive seen is mcm1000 in 3 conductor clx cable. Its takes a minutes to cut threw it with a bandsaw!
im not looking to seal off im trying to stay out of wall classes and plan on staying in trunk classes
15
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
ChaseinBass
ChaseinBass
Calif
Papermaker85
