MTX T1501d 1500 watt mont
RayRay1417
MTX T1501d
These amps are absolute beast. Extremely underrated they do a little over 1500 rms on 12.4v @2ohms and they can be modified very easily to drop down to 1 ohm giving you around 1800 rms. On 12.4 Any one who has run one of these will tell you that the are absolute monsters. It's always been
On proper voltage and was taken care of properly. I also have second one that will be up for sale here in a day or two it was missing the power and ground screws so I have to order some ten I will post it. Both can strapped together to give you over 3200 rms and if both are modded they will give you over 3500 rms. If your interested in both let me know and we can work out a deal
$275 shipped second day delivery
On you
Item Pictures:View attachment 26549756View attachment 26549757View attachment 26549755View attachment 26549758View attachment 26549759View attachment 26549760
300 shipped for the perfect one to the lower 48. 185 shipped for the one missing the screws wich Is an absolute steal the set screws can be bought from ebay for under $5 and the power and growing can be replaced with bolts from any hadware store or also purchased from ebay. There the same studs that are in most 0 gauge wire connectors
Fwiw, I ran mine modded for years @.8ohm with zero issues. It did NOT run hot at all, I'll assume that comment came from someone that has never owned one let alone a modded one.
The mod will allow up to 18.5 dc volts and down as low as you feel comfortable on impedance... I wouldn't suggest any lower than .5 for daily with good steady voltage. As for the removal of the protection circuit, just don't touch the speaker leads together while the amp is on and all will be well.
With that said, this amp is a proven powerhouse both in original and modded form. There's a reason they've kept there value over the years...
Your a absolutely rite. I've done the mod on a couple amps over the years and I never had problems. Although it will run hotter than normal if your voltage isn't up to par and you trying to get too much out of the amp. I also live in south FL so all my amps tend to be kinda hot so I've installed 4 PC fans and they stay nice and cool
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
863
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
According to Crutchfield, those JLs won;t fit in your dash, can't see why, just what it says on their site. it says those JL's won;t fit in the...
RayRay1417
RayRay1417
South west florida
1-12-t1
Decebal
    Jun 10, 2024
