MPEG Player
there is a way to convert downloaded movies into a .dat file and put them on cd and they will be read as a vcd by most dvd players, how to convert them i dont know though been trying to figure it out my self
go to http://www.vcdhelp.com and learn all about vcds. it involves more than just converting and burning. I found it easiest to use Nero and let it encode and burn, but saving quality in audio and video is the hardest part. Nero looses a lot of quality. vcdhelp.com though has a ton of resources, programs, and tutorials to teach u how to make VCDs. Then just find a dvd player that also plays vcds(most do). good luck
when the program opens and asks which type of CD to burn choose Video-CD. If you are burning multiple video files, then you can choose to Enable the menu using the tab on the top of the window, doing this is self explanatory. Then Simply click New and the 2 windows will open, find and drag your video files to the VCD window and let it scan the file. A window might or might not pop up but if it does click to re-encode the video and then just click to burn the CD as usual.
shouldn't take any longer to burn than a normal cd unless you choose to rencode video files. just as easy to turn off standard compliance if the video is close to the right size.
wow 3 hours at 24 x... well the videos have to be like 320 x 240 but i mean if its 310 x 230 or something like that the video will just tile the other 10 pixels......
Is there a BT, USB or other AUX option? May be time to convert your CDs to a solid sate option and use it until you replace the init altogether.
630
you did. https://www.caraudio.com/threads/double-din-cd-player-with-screen-mirroring-a-link-android-auto-budget.614240/#post-8864499 OP:
AGAIN sonic does the same install stuff for free as well! Get a head unit with 4v preouts and 6 rca preouts as well they will be setup as front...
19
i3abyjay25
Get F'n Loud
i3abyjay25
Dallas, Georgia
Fuel37
