You would HAVE to take an after pic for us if you did that.I was just going to knock random holes in the wall until I got it right.
It is 16" in my state I believe.wall mount ftw.get one with a tilting option. with tilting you can level the screen to face your sitting position a little better.
finding a stud isn't too hard. i forgot what the rule of thumb is for inwall bracing/stud. i recall the 2x4's run parrallel every 12-13"s apart.
Hide your wires yo.for what i did i took a rubber mallet an knocked on the wall gently to listen for hollow and solid sounds. i then took a very thin nail and hammered it into the wall. if the nail goes thru with ease then your not on a stub. if it take a bit of force then you found one.well, the wall mount that i have for my tv has 4 long oval spaces as to where the mounting bolts should sit in. i took a pencil and traced those ovals on the wall and searched for the stud in those ovals. be sure to use a level. if it's not levels when you sit the wall mount the tv will clearly show it's not leveled. that is something that stands out to me and may not to others.
they say you really only need 2 bolts to be in studs but it's best to get all into a stud.
set the tv's center point to your eye level. and give a slight down tilt. not much just a little. it's how mine is.
The type you are looking for should be $40 tops. Should be 4 bolts to fasten the mount to the wall. All hardware should be in the box. Make sure you level it and bolt to studs. All else is cake.The tiliting type would help with the wires and allow a greater mounting height. I'd like it atleast 42" from the floor to the bottom of the TV. I think it would look odd for it to be 3'.
i live in military housing. i can't modify in wall cable drops on their wall. unless if it was my house then yes there would be no wires. it doesn't bother me much. it's my bedroom so no big deal. the living room 52" stays on a tv stand so that area looks clean. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifIt is 16" in my state I believe.
Hide your wires yo.
I am still iffy on how high I want it though...The type you are looking for should be $40 tops. Should be 4 bolts to fasten the mount to the wall. All hardware should be in the box. Make sure you level it and bolt to studs. All else is cake.
are you only 3' tall??The tiliting type would help with the wires and allow a greater mounting height. I'd like it atleast 42" from the floor to the bottom of the TV. I think it would look odd for it to be 3'.
