mounting sub
jr15
ok guys today i am installing 1 e10kd4 into the wifes car running off of a kicker zr240...this will be going into the trunk of a '98 malibu...what i want to know is if there is a way that i can mount the sub..but also be able to remove/move the sub around if needed...you know for groceries etc...thanks guys for any help
Well, you can use a very small box for your K. I suggest using a wire terminal on your box. . . so all you need to do is unplug the wires from the box when you need the extra room. I believe the 10" K series can be placed in a sealed box of only .3ft^3.
- Steve
jr15
jr15
Steelton, PA
denim
