mounting inverted
BoomBoxStereo
@woofergram
i have my two subs wired down to one ohm... all i need to do is reverse the speaker wire into the amp, right (positive in negative and negative in positive)?
my headunit also has a 'reverse' setting... does that just reverse the polarity on the headunit or can i just use that instead of rewiring?
thanks
you dont wire them any different, you just change the phase on your amp and reverse polarity on the HU brah
What if your hu doesn't have a reverse option on it? And phase if there's a 0 and 180 switch do you switch it to 180? Sorry op just curious. Lol this has always confused me.
Whether you do it at the head, the amp, or the speaker terminals, it's all the same thing. Being able to do it with a switch on the amplifier is more convenient than rewiring the drivers. Doing it at the head is more convenient than getting out and doing it at the amplifier. Choose one and only one way to do it.
The reason you're doing it is to get the best phase integration between the front stage and the subwoofer.
Fuck...
Often times running subs out of phase blends with mids better anyway. I never even pay attention to phase going into my woofers and typically test on the HU and go with whichever blends best.
BoomBoxStereo
@woofergram
BoomBoxStereo
Long Island, NY
skylineTT
