well, i went ahead and did it, the mdf on the bottom dosnt really slide around at all to my knowledge.pm sent:santa:
with the weight of the mdf on bottom/false floor/weight of the box with the subs in it,all atatched,it should be pretty heavy,and you should be able to attatch amps/dist block/fans/?whatever you want to it..It looks much better under the carpet where you cant see it/false flr/mdfwell, i went ahead and did it, the mdf on the bottom dosnt really slide around at all to my knowledge.mount pictures by cbuts05 - Photobucket
yeah, idk, i cant afford carpet atm so im going to leave it as iswith the weight of the mdf on bottom/false floor/weight of the box with the subs in it,all atatched,it should be pretty heavy,and you should be able to attatch amps/dist block/fans/?whatever you want to it..It looks much better under the carpet where you cant see it/false flr/mdf
what about sliding the mdf under your trunks carpeting then screwing through it, that would clean up the appearance a bit.yeah, idk, i cant afford carpet atm so im going to leave it as is
whyChevy Malibu? you should post the bolt pictures of your alternator + and engine block ground please //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
