Mounting Amp(s) to enclosure
c_hayhurst
Due to limited space, I will need to mount at least one amp to my sub enclosure.
Besides placing the amp on a layer of RAAMmat or Dynamat, what else can I do to minimize vibration/flexing placed on the amp?
This really is a good problem to have: 3 amps, 2 subs, 900W RMS per sub. MUWAHAHAHA!!!
If the enclosure is built solidly, you can mount the amp to it with no problem. Vibrations from the subs are going to pretty much be the same oll over the car and are generally less than the jolts caused by driving on crappy pavement.
If the enclosure is secured to the vehicle like it should be it will be hard enough to steal that having the amp bolted to it might make it more secure.
c_hayhurst
c_hayhurst
Columbus, Ohio
Symon_say
