4 JBL clowns could do it. Or a couple Zapco 9.0's. You would need a lot more than jsut batterys. Probably dual alts of 300amp+. IDK, talking about some serious power here!!
Jon
wrong. impeadance changes radically with movement of the coil.110^2/1 = 12,100 watts ...
Easier than you think actaully. 8 modified mtx 1501d's running at 17.5v dc and with a DCR of 0.7 each. Under those conditions at 47hz, each 1501d was generating ~2600watts. (5200watts a coil x 4 coils.) That's why you used to see mtx in a LOT of ss and extreme vehicles in the drag lanes.how many amps and batteries would one need to get 20kw ?!!?!?
Wrong again' date=' sorry to tell you. It equals volts, not watts. tho I dont know how to convert, i know they ARE not the same thing! Volts is a measure of steady power, wereas watts is a measures of how much work can be done.wrong. impeadance changes radically with movement of the coil.
The typical outlet is fused/breakered at 15 ampres. So:
P = VI
P = (120vac)(15a)
P = 1800 watts.
Even if the outlet were stable to 30 ampres:
P = (120vac)(30a)
P = 3600 watts.
uhhh.. you're wrong, Power(watts) = Voltage(volts) x Current(amps)Wrong again, sorry to tell you. It equals volts, not watts. tho I dont know how to convert, i know they ARE not the same thing! Volts is a measure of steady power, wereas watts is a measures of how much work can be done.
P = VI
P = (120vac)(15a)
P = 1800 VOLTS!!
P = (120vac)(30a)
P = 3600 VOLTS!!
Easier than you think actaully. 8 modified mtx 1501d's running at 17.5v dc and with a DCR of 0.7 each. Under those conditions at 47hz' date=' each 1501d was generating ~2600watts. (5200watts a coil x 4 coils.) That's why you used to see mtx in a LOT of ss and extreme vehicles in the drag lanes.
Even a single JBL crown 6kw will hit 10kw with a little modding.
Zapco 9.0s? You are going to need 7 of em to break over 20kw.
All of the above are going to need GOOD voltage supplys, so as many batteries as you can afford.[/quote']
How do you mod an amp? Soldering chips?
BTW a 12" pyle took a welder for about .5 seconds. The welder was set to 300 amps.
P = VI
P = (120vac)(15a)
P = 1800 VOLTS!!
P = (120vac)(30a)
P = 3600 VOLTS!!
Wrong...j/kNot quite' date=' but I'm glad you see that now. To elaborate a bit more let me demonstrate EXACTLY what a volt and watt are, and use a proof to demonstrate! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
1 volt = [1(kg)(meter^2)'] / [(second^3)(ampere)]
1 watt = 1 joule / second
1 watt = (1 Newton)(meter) / second
1 watt = [1 kg/(second^2)] (meter) / second
simplifying we find:
1 watt = [1(kg)(meter)] / (second ^3)
therefore:
P = (I)(V)
1 watt = (1 volt)(1ampere)
1 watt = ( [1(kg)(meter^2)] / [(second^3)(ampere)] )(1 ampere)
1 watt = [1(kg)(meter^2)] / (second^3)
And that is WHY Power is in the SI units of Watts. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif enjoy!
