Most Efficient Small Amp Big Power * Build To Come*
ya just looked them up nice looking amps but really pricey i am still on a bit of a budget i would like 200 if i could get around that might not be possibly though which having to have an efficient amp and more power the better //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif i like how both that and Taramps list the Amps True Draw and amperage . that is part of probably when i am looking them up is no one really lists that online
Go for the Alpine PDX-M12. 1200w @ 4 ohms (If you can wire to 4 ohm) either that or 1200w @ 2 ohms. At 4 ohms it'd be incredibly efficient. It's a little more, close to $500 off ebay. I currently own the PDX-F4 and I can vouch they are incredibly tiny, compact, powerful, efficient amps.
the Taramps HD1200 looks decent specs below any local supplier in north america for this stuff though?
Number of Channels: 1
@ Max Power 13.8 VDC - 1 ohm: 1439W RMS
@ Max Power 13.8 VDC - 2 ohms: 813W RMS
@ Max Power 13.8 VDC - 4 ohms: 446W RMS
@ Max Power 12.6 VDC - 1 ohm: 1200W RMS
@ Max Power 12.6 VDC - 2 ohms: 678W RMS
@ Max Power 12.6 VDC - 4 ohms: 372W RMS
Input Sensitivity: 250mV @ (-9.78 dBm)
Total Harmonic Distortion (THD): 0.3%
Frequency Response: 10Hz to 15KHz
Crossover:
HPF (High Pass Filter): 10Hz to 50Hz (-12dB / 8 th) Variable
LPF (Low Pass Filter): 50Hz to 15KHz (-12dB / 8 th) Variable
Bass Boost: 0-10 dB (50Hz)
Input Impedance: 18K ohms
System Protection: Short in the Output / Input Voltage High / Low
Low Supply Voltage: 10.5 VDC
Maximum Supply Voltage: 16VDC
Consumption Sleep: 1.20 Amp.
Maximal Musical @ 12.6 VDC: 57 Amp.
Maximum Consumption in sinusoidal signal (1kHz) @ 12.6 VDC: 114 Amp.
Dimensions (WxHxD): 229 x 65 x 205mm
Weight: 1.98 Kg
Crossover:
Weight: 1.98 Kg
Shizzzon on CACO (Car Audio Classifieds - Buy, Sell and Trade Car Audio Equipment) sells it, under SPL labs vendor section. If you want small and effecient look no further.. The Taramps HD5000 I have is smaller than my Sundown 1500d and at 4ohms, so 3k RMS, I can run it off stock electrical no sweat. (wired for it's full output I'd need to upgrade though)
cockerchrisjoe
cockerchrisjoe
Uxbridge, Ontario, Canada
T3mpest
