Ya the bpx are ab and great amps but like powerNot the same amp I was thinking of
^this^^ amp efficiency is measured at 4ohm and usually at 100HZ dropping your amp to 2-1-.5 ohms completely destroys its efficiency,yes there are amps that will draw less amps at 1ohm than some other amps,but you need to remember the less(power) an amp takes in the less(power)it will put outEfficiency has always seemed to be a pretty gray area to me.I think most companies that bother actually measuring efficiency are going to specify the best number the amp could achieve.
That's probably not full power, minimum impedance.
It always seemed to be a silly thing to worry about to me.
If you buy a quality amp of a particular class - in most cases it's going to give you reasonable efficiency.
And any other comparable amp - while i would expect efficiency would vary - shouldn't differ by much. To be concerned with a few amps one way or the other isn't going to make or break the system.
and the difference in efficiency can often be drastic between amps, also mmats does all their efficiency ratings and the lowest rated ohm load... or at least the last i checked they still did.^this^^ amp efficiency is measured at 4ohm and usually at 100HZ dropping your amp to 2-1-.5 ohms completely destroys its efficiency,yes there are amps that will draw less amps at 1ohm than some other amps,but you need to remember the less(power) an amp takes in the less(power)it will put out
RARE Phoenix Gold Xenon X1200 1 Amplifier Beastly Strong Amp | eBay
really nice amp 1200rms at 1-4 ohm and run at 4 ohm //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif over 80 percent effecient
Its Class D, and is by far the most efficient amp mentioned in this thread so farIsn't that A/B? Not to efficient if it is
