Morel MW-266 8" Pair
ciaonzo
TheContinental
11,703
76
WI
BNIB Morel MW-266 8" midbass/midrange pair 8ohm
Brane new. Very wide bandwidth 8", good from 22Hz to 2.2kHz. Shallow! Less than 2.75" depth. I removed one of the foam filters since it wasn't glued properly. Otherwise, perfect. These do not need a lot of power!!! Whatever amp you have will be fine. Tired of you guys bellyaching over the 8ohm thing, lol. I absolutely guarentee that you will love the sound from these even with low power.
Stupid low $185 shipped, CONUS.
CONUS only, please.
I'm lookin for a pair of midbass drivers for small sealed enclosures for under my front seats...how would these bad-boys do in .2 cubes each w/250 rms each crossed from 50hz @24db - 200hz @24db?
.2 for low bass would not work very well but for the 50-200 range you would be just fine. Thermal is great on these and they are quite shallow.
Nice thing about the Morels is they don't require a lot EQ. Since the midbass will likely be far from the mid & tweeter, you could benefit from...
  • Locked
Looks familiar: https://www.caraudio.com/threads/who-needs-new-equipment.613325/ Wouldn't that be a real kick in the ass. I shared that so...
Like OP stated, there are radios with higher power output. Most radios have around 18 watts RMS per channel. They mostly claim 50w per channel but...
18
4K
ciaonzo
TheContinental
ciaonzo
WI
ciaonzo
    May 18, 2024
    May 18, 2024
