More Stetsom 10KD Testing
uptwome2007
I got a chance to do some more testing with my 10kd today. For the first test I wired it at .5 ohm on 3 fully charged Kinetik 16 volt batteries. For subs I used 2 Soundstream T5 12's. Here are the results...........................
Start Voltage..............17.5
Drop Voltage..............12.8
Ac volts.......................87
Ac Amps......................88
Watts.....................7656
Imp Rise..................... .99ohms
The second test I used 3 fully charged Kinetik 16 volt batteries. For subs I used 2 Soundstream T5 12's wired at 2ohms. Here are the results.....................
Start Voltage.............17.5
Drop Voltage..............13.8
Ac volts.....................142
Ac amps.......................37
Watts........................5254watts
Imp rise.....................3.84ohms
***All measurements were taken after 4 seconds into burp***
See how even with higher impedance it does more power. These amps don't need to be run into the ground to get power. Point proven at 2ohms still does over 5k. And wonder why you're hardly getting any impedance rise out of those subs? That amp loves 1.5-1.8 after impedance rise for maximum efficiency and power. Nice job
more like 5kw @ almost 4 ohms, even with the voltage drop
Why such a huge voltage drop? Running just off batts for power?
Solid power output, but the price chased me away...
How much would you expect to pay for an amp that can deliver this much power on 12v? $2000, $1800, $1600, $1400, $1200 or less?
Tree Fiddy.
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif:p:
Both of the tests that I did had voltage drops below 14volts. So they actually are 12 volt tests. If your suggesting that I run 12volt batteries....The 10kd was not optimized to run below 12volt, so I could possibly damage my amp and I can't afford to do that.//content.invisioncic.com/y282845/emoticons/nono.gif.eca61d170185779e0921b0faa9704973.gif
Correction, below 10v. This amp is designed from 10-18v.
uptwome2007
uptwome2007
new jersey
DBBOOM
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
