More power, less sound?!
also another thing jumping from 150 watts to 550 watts is actually a lil less than a 6db gain. i don't know how much of a difference you might hear. I as well jumped from 625 watts to my current 160 watts and did hear the 6db loss somewhat.
One more question. The pos/neg on each voice coil are reversed. So the wires will have to overlap eachother a bit. This won't cause any interferrance will it?
It will be like this:
Um it actually looks like the way he has it wired up now he's only running one of the coils. He has the + from the amp going to the first coils + but then the - from the first coil going to the - on the amp. The second coil isn't actually connected to any power. He would need the negative on the first side to go to the positive on the second side. If you have it hooked up like that currently you may have damaged your sub. :/ At any rate don't play it any more till we get this sorted out. You are unevenly driving the sub if thats true. Anyone else look at that diagram and make sure I'm understanding it right?
Ugh don't tell me that //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif I've only had the sub in for about a week. If it WAS causing damage, do you think the sub is still ok?
On the positive side I have it all wired up, just have to fasten the sub back in, then take it out to my car.
he originally has the coils wired in series. which is one negative of VC to other positive of other VC. then other negative and positive to amp.
edit: it was wired okay. just to 8 ohms.
If it doesn't sound metally or make any funny noises it probably isn't broken. Here I made these diagrams off of yours. #1 is your current setup. #2 is Series yielding 8 ohms, and #3 is Paralell yielding 2 ohms.
ripxtide
ripxtide
Canada
Do_
