more mid bass?
so nobody wants to help me out hmm guess ill try it and see.
does anyone think a pair of bass shakers could pull the bass forward if i mounted them under the front seats running stereo
Deadener definitely doesn't help midbass output. Just throwing that out there.
You're right, it reduces the overall output by reducing resonance.
Having sheet metal doors ringing out at 120Hz certainly doesn't help the system sound worth a darn.
I prefer accuracy over output. Deaden all you want, it won't come close to how dead a proper MDF enclosure could be. But we certainly don't build enclosures with thin sheet metal... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I try to make cars not sound like cars.
well a suggestion of how i would get my bass to sound like it was more in front of me would help. id rather not have to build pods or kicks. my doors are deadened inner liner and outer door skin plus mlv and ccf really dont think i need to do much more to them. i can run more power to my mids right now but it would require a higher hpf setting and they are already getting 80w a piece. if i need to put subs in front of me the only option i really have is on the ***** hump.
well bass or midbass? sub bass should be omni directional.. so IDK exactly what you are looking for.. if there is not enough midbass and you don't want to do more work to the doors than different speakers would be your answer.. or more..
I'm thinking different speakers. You said your current ones extend to 50hz at moderate levels but to 63hz when u crank it...so they're extending low enough...sounds like u just want more output. In that case, if you cant upgrade to 8's, try to find a 6.5" driver that will move more air (more efficient, more excursion...).
Also, I'd check to be sure you're not getting any cancellation...T/A or flip midbass phases, reverse sub polarity...all free things you can try.
Maybe try a lower xover point on your subs? steeper slope? make sure its not rattles in the back giving away sub location? ...
just bass when i have my system playing low you cant really locate where the bass is coming from due to the mids overlapping with the subs but when you turn it up to where i comfortably listen to all the bass seems to be coming from the back and rather than dial down my subs id rather find a way to bring the bass upfront.
i have seem a sq competitor actually put a 10 in the dash of his car to pull the bass toward the front. and i was wondering if anyone had experience with this. my mids cant keep up at higher volumes which is why i thought a sub with a high fq tune could help mesh the system together. im no sq competitor but i would like or it to sound good.
if it takes my building pods then i will i just really dont have the time right now to do fiberglass and the weather stinks right now wet and rainy + fiberglass = waste of my money
Ive seen cars with 5.25s upfront have good upfront bass. Its just all in how u make it work. Sounds like youre really looking for more midbass output. I hear the Massive CK6s are very strong on midbass. Also if u haven't already, bridge the amp to your fronts.
Could be the subs or enclosure too. Like stated, the bass should be omnidirectional. Some subs are simply not good in this regard and when u really crank em, they'll give tthemselves away. A better enclosure helps this sometimes.
Sounds to me you're trying to use your mids to compensate for an inadequte sub install. Midbass and bass are different, and as stated earlier bass is omnidirectional and various things can cause the bass to be noticeably coming from the back of the car. Increase in midbass wont correct this.
Now if you truly are lacking midbass, the only options I see would be using dedicated midbasses in the doors and 3-4" mids elsewhere, or get more efficient mids or ones with more excursion and power handling and add the appropiate power
i dont have rattles and the box is sealed downfiring. my mids normally cross at 80hz and the sub the same when i demo though i lower the hpf to 63 since it sounds better at moderate volume and if i have a couple guy who just want to hear bass anyways it makes the bass stand out more and since the subs are behind me under the rear seat u can pretty much tell where they are. truck boxes sux i know this.
maybe i need to try a lower lpf.
i really wish i could build a ported box tuned to 30 like i normally do but i would have to drop down to 1 ten or a pair of daytons. and since this is a shop demo truck i need to run what i can sell.
unfortunately u cannot bridge the rockford pbr300x1 but i have a pair of pbr150x2s coming in that i can try the mids on one with. im just concerned with the power handling on the mids. while memphis has amazing quality its hard to find anyone running more that 75w to a set let along 80per mid. i could swap them with a set of the 8s they make but i still would have to cut up my door for this
You might be better off with a single good 10 ported. Especially if its a bit more of a quality sub than those shallow mounts. What are you're other options for subs? I might have missed it, but what slope is your lpf? Sealed shallow mounts without a sharp slope could definitely give away the subs location, and possibly even overpower your mids at 80-100hz. Try a lower lpf for sure.
trying to stay with rockford or memphis thinking maybe 1 p2 10 or memphis pr or m class 10 ported but the shallows really surprised me.
the current slope is 80hz at 12db slope lpf can switch to 24db
and 63hz at 12db hpf during demos and 80hz and 24db hpf daily
i think om gonna try and lower the low-pass and try the steeper slope at current settings
my eq is flat right now save or a 2db boost at 32hz
show a picture of your doors as they are now - with the panels removed.
deadened does not imply fully sealed. you need a near airtight seal to get midbass. that includes seals on the front of the driver - sealed to the door panel. but sealing the large holes is where you get HUGE midbass gains.
on the scion we had the doors like this for a few months
midbass was ok but not great. everything was good but we knew the ML woofers could be better.
then we closed them up like this:
amazing difference. more midbass than we could ever want or need. ran without a sub for a year and had useful response down to 50Hz with the ML-165 woofer.
That mid is why you had good midbass. Same with the AA poly or CF mids and the Exodus Anarchy. They all play low and have a lot of xmax...
winkychevelle
winkychevelle
Ponchatoula, La
okiedokie
