Monoblock has two inputs
  • 7
It's all about how the subs are wired to a final ohm load. The amp doesn't know until the speaker wires are connected. As I said, some mono amps have split internally to give the user flexability. The MTX Audio 1500D amp is a prime example.
every mono amp, has one output. it may have 2 or more sets of terminals, but its still one ouput, just split, so you can hook multiple sets of wires easily....... also, if it smoked, something is not "just fine"..... something smoked, and that means something burned, and is damaged. no exceptions.
Yup I told him how to wire it to 2 ohm and it's fine now. No heat. I wish he would've gotten dual 4s though. For some reason a lot of people think that two D2's go to 1 ohm. I tried to tell him he needs two D4's but he didn't listen. Same thing with one of my other friends that got two SA-12 D2's. I don't get it
Show them that JL Audio chart I linked on here, wiring subs. If they still don't wanna listen, let them burn their **** up then.
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
To me.. It looks like the Allen head screws are in the terminals on the speaker inputs on the amplifier. The negative looks like its in there and...
Thanks man I’ll give it a try I’m usually pretty bad at this kind of stuff. I wasn’t sure if there was a website or something that had a picture I...
  • Locked
GM-D9701. Used it to power a sound quality sub (Adire Brahma 15”). Was adult owned and carefully used (had a Mini DSP connected to it with a...
Those are my HDS310s S.Qubeds. I havent tried my XFL 10s in that enclosure yet.Something to consider just to see how they do. I may try it out one...
Based
Based
Louisiana
Boomin_tahoe
    May 18, 2024
    May 18, 2024
