dlow265
im new to mono block amps and wanna know if you can wire your dvc sub to it and give the amp a 2 ohm load to get all the power out of it?
Is your sub a dual 4? If so, yes.im new to mono block amps and wanna know if you can wire your dvc sub to it and give the amp a 2 ohm load to get all the power out of it?
two channel should be able to do 4ohm bridgedcool thanks man. now i can get the right kind of amp i am running a 2 channel amp to a dvc and can only do 8 ohm load. that sucks!
