mono amp question
Rockford Fosgate® - Woofer WiringWizard
what subs do you have
So if you wire 2 subs seperatly what happens to the impedance like let's say I wire each sub @ 2 ohms and run separate wires to all 4 of the inputs that makes the amp send out a 1 ohm load right?
The amp doesn't send out ohms LOL. You are wiring the subs in parallel, so assuming they are of the same impedence, it halves the impedence.
^sorry about that I worded it wrong lol
My subs are dual 4 ...so let's say I wire them seperatly down to 2 ohms each and run each sub seperatly to the amp I would get a final impedance of 1 ohm or if I wire them at 8 ohms each I would get a final impedance of 4 ohms?? Is that what u mean
^sorry about that I worded it wrong lol My subs are dual 4 ...so let's say I wire them seperatly down to 2 ohms each and run each sub seperatly to the amp I would get a final impedance of 1 ohm or if I wire them at 8 ohms each I would get a final impedance of 4 ohms?? Is that what u mean
Yep, that's what he means and that's the correct answer. Wiring each to 2 ohms and wiring each to the amp is no different than wiring both together down to 1 ohm and wiring them to the amp that way.
big nick
big nick
Long Island
daboyfrumdabx
