Mono Amp and Speakers
most monoblock amps are for subs. it probably has an internal subcrossover i am guessing. if your amp has a switch for the crossover to select high pass, low pass and so on just use that setting so you aren't sending a low frequency signal to your speakers( i guess you are wanting to run some mids and highs with it). You should be able to use it if you have either a component set that has its own crossovers or have an electronic crossover to hook to the amp inputs to filter the low freq's out. It is probably 2 ohm mono stable so you can wire up a pair of 4 ohm speakers in parallel to it with no trouble. How many speakers are you wanting to run with it? Only thing is that you won't have any stereo separation or any kind of contol other than the gain on the amp.
solidcrowd
solidcrowd
Buffalo, New York
h17250x
