Molded Amp Rack
wasted ink
wasted incorporated
self explanatory.. still not finished, but heres what i got so far..
awesome. how are you gonna get the amp wired up? will it fit back in with the rcas plugged in and everything? or are the inputs tucked in?
nope, that was the tough part. it goes in through the bottom, in a tricky way.. as you can see on the bottom side, the holes (where the fiberglass is) is where the wires will be fed. the power side will have holes drilled above the terminals to get a screwdriver in to tighten, where the rcas i can just plug in from underneath.. tricky, but it will work. ill show how in the end. thanks man.
thats a pretty good idea. it should look pretty sweet, im thinking of buying some more mdf and glassing materials soon and see what i can come up with.
wasted ink
wasted incorporated
wasted ink
Southern NH
wasted ink
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
