MOJO 4kw benched?
200 amp alt. Yellow top up front, 2 Kinetik 2400's in the trunk and a Kinetik 2000. At start up idle is 14.4 Time of test voltage was at 13.9 Burping a 49hz tone I was dropping in the high 12's after a few burps I was dipping to 12.0 and then I decided that was enough of that. I do not recall the rise. Maybe by some chance if TOMMYK stops in he may remember. This was a while ago so i wouldn't count on it. Sorry I could not be of more service.
Yes, I've heard that. I'll be running a 250 amp alt, stock batt under the hood for now, 2 g34 blue tops in the rear, amp running at 1.5 ohm. I think I'll be okay with that setup.
Yep, will be fine with that setup. The older model 4K will do 3-4k at 14.4V. Some people claim ridiculous numbers like 8KW at 16V but I don't think so. Output section in 4K is more like what is in most 3K rated amps, but the power supply is like what is in 5-6K rated amps so even it were pushed to the max outputs would likely blow.
Low voltage doesn't kill Memphis 4K's vibration does.
In my investigations, I have seen claims that are all over the place as far as what causes them to blow. On termpro I saw people saying they were dropping to 10ish volts, yet others are saying below 12 and you're in trouble. Thanks for chiming in db-r, I appreciate it.
itll burn up if your elec isnt up to par
Man i heard that alot, but i seen my friends first hand below 11 and .5....guess he just got lucky
It drawssss some current.
But we got like 4300 outta it at .33 nominal and i think rising to 1.1ish......cant remember voltage on that one
He had 6 2400s , and a 220 alt
It puts out some power for sure, but too give an idea of efficiency or clean power, when we tested back to back with a 40.1, the 40.1 put out a lil bit less power(or the same) but always a higher score.
cx-7heaven
The dash don't be silent
cx-7heaven
Savannah, Ga
Skip01
