Sold Mobile Authority MAX-1
RidnClean
Love 4 Money
got this in a trade from Louisiana CRX, thought i could find use for it, but nope.
here's some info
Mobile Authority MAX1 Crossover
Subwoofer Elec. Crossover Network
-Gold Plate RCA(IN/OUT) Jacks
-High Imp. (Low LVL) input acceptable
-Independently variable L&R input LVL controls
-LED power on indicator Lamp
-3 Selectable Low Pass X-Over points (75,100,150Hz)
-12dB Bass Boost(40Hz)
-Slope Rate: 12dB/OCT
-Input/Out Ratio: 1:3
-Distortion: Less Than 0.02% @ 1KHz
-Signal to Noise Ratio: More than 80dB
WHAT IT IS/DOES:
It will work as an LOC converter....for factory decks the high inputs...Or it will work with after market decks with RCA's the low inputs and It is also a Sub woofer crossover with independant ch. gain adjustments and it has a built in line driver that can boost the input 1:3 so 2 volts in upto 6 volts out....5 volts in upto 15 volts out
$25shipped
or trade?
It will work as an LOC converter....for factory decks the high inputs...Or it will work with after market decks with RCA's the low inputs and It is also a Sub woofer crossover with independant ch. gain adjustments and it has a built in line driver that can boost the input 1:3 so 2 volts in upto 6 volts out....5 volts in upto 15 volts out....at least thats what I gathered from the info....it is a pretty nice processer it also has a plexyi cover to keep dust from enetering the adjustment pots......
RidnClean
Love 4 Money
RidnClean
Washington
RidnClean
