MM4000.1 1 ohm stable?
Ahhh....it'll out the amp trying to see .5 and prolly not rise high enough to play daily
You could try wiring in series than hooking up mono and be at 2ohm be decent power....or one ohm stereo for 2000watts
if you wire a dvc 2 ohm sub in series..you get 4 ohms......no matter what you do from this point as far as hooking the positive and negative wire to the amp....it is still 4 ohms no matter what
4ohms mono would be 2ohm actual
this is incorrect...4 ohms is 4 ohms no matter what. if there is one positve lead and one negative lead hooked to the amp...you cannot change the load load simply by changing what terminals on the amp you connect those 2 wires to.
Well hard to explain....but why do you think the rating is 4000x1@2ohm mono and 2000x2@1ohm stereo
Or that its only 2ohm stable mono but 1ohm in stereo
this part i understand fully
only time ur amp will see half the ohm loadage is when u bride the amp/ run it mono that means 1 positive on left side of the amp and negative on the right side of the amp u get the point. so yes if u had an single 4 ohm vc sub and wired it to the amp mono then yes each side of the amp will see an 2 ohm load. like i said ive heard these amp sweet spot is around 3.3 ohms so depending on box and port size. id keep the Dual 2 sub and wire it @ 4ohms mono. maybe ur imp rise wont be soooooooooo bad and u get around the sweet spot 3 ohms
thats the key point here....each side....so 4 ohms mono is not 2 actual....its 2 ohms per side.
:Dbasically same thing we sayn/ or tryn 2 say:D
Yeh..its hard to understand if you never had one....haha.....i cant explain it better really
Its not a mono amp...thats the biggest key....i know mono amps have 2 sets of terminals to but they are internally strapped so it doesnt matter...that would be what ur thinking
This is not internally strapped....its 2 separate 2000 watt amps inside
well i told u that ive been running the amp 1 ohm mono for an while now with no problems. oh yea and thats with AN SUCKY electrical. only problem i have is it kicks into protect from time to time. but thats only because of low voltage.
ya i read it...but i dont feel like reading the whole 6 pages..but if u would be so kind as to simply throw me an answer....1 ohm mono for daily..yes/no?
Well if ya dont wanna read ya dont wanna learn......good luck
mi amigo! that hurts me deep...after all we've been through?//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Seattle206
Seattle206
seattle
Seattle206
vegang
vegang
