MLA module issue
RetroAudioinc
Custom Car Audio Decals
So I got a mla module for my chevy 2500HD 6.6l and I plugged it in and all. It works great 15.8v full tilt drops to like 13.5 if not on gas, on the gas stays up there. But my problem is my AC will not work when the MLA is on.
It blows and all but not cold like something is not kicking in. Only issue I have found with it.
Any help would be great..
Mine has to blugs one to plug the stock plug in to and the other plugs back in to the alt like a pig tail. I unplug it and plug the stock plug in ac works fine.
Being in Florida I kind of need AC, so I just plan to use it at show(s) with out the AC. So it's fixable you just can't use the AC and MLA but kind of sucks. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif I was not sure if there was some kind of fix for this.
sounds like you got the pro version that has a switch on it to change from 14.6 and 15+ volts maybe you need to switch it. if not then there is something wrong with the mla i don't think it should be chargeing that high of
Sheyot if it brings up the Voltage I might just look into it. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Really sucks about losing the AC. Something just doesnt sound right.
RetroAudioinc
RetroAudioinc
Indianapolis, IN
GJGJ
