Mids & Highs Wiring?
  • 2
itscody
20
West Va
I was wondering which way id get the best sound from my mids and highs.
If i run all speakers to the cd player using the wiring hardness or just directly to it. or if i run them all to a 250watt amp?
Also should i run a seperate rca cable from the deck and hook it up to the.
Front audio L & R output
or
Rear audio L & R output
or just run them from the same rca's i use for my amp for the subs?
Sorry for posting in wrong catergory i just now noticed that.
You'll want to use seperate RCA cables for your multi-channel amp, bro. You'll want to bypass the speaker wires at the h.u. as well.
- RCAs from h.u. to amp
- Speaker wire from amp to speakers
Alright man thanks i noticed your from west va also.
Also do i wanna use front or rear output?
Lol.
Alright ill try altough my amp only has 1 input and output and i use the rear out put on my h.u for the subs because the subs output dosent hit hard and sounds weird.
heres a disgram for the rcas - http://www.sbo2.net/photo2/1022/1022-05.jpg
Hmm, sounds like you're trying to use a mono amp to power everything. I wouldn't recommend that, man. If you don't have a multi-channel amp, you'll need to power your door speakers with the h.u.
What equipment do you currently have (cd player, amp, sub, speakers)?
Hmm, I'm a little confused, man. Are you having a difficult time understanding how to run both amplifiers at once or what? If not, I really don't see a problem here. Your cd player has front, rear and sub outs and you have two amplifiers. You should use the sub output for your SPL amp and the front output for your 2-channel amp.
I'm having trouble locating info on your SPL amplifier, man. Knowing the model #'s for your Pionner and Rockford Fosgate speakers would help me quite a bit too. Simply put, I need more info to really help you...
Ch 1 and 2 can be bridged and 3 and 4. The amp shows you where to put the speaker wire to bridge it. It becomes a more powerful 2ch.
32
6K
Hell of a deal, I think it may be the last day. If you're considering going to a 3 way, here's a great buy! You have to load them into your cart...
I agree with DJ. Pro style speakers are designed for large ported enclosures and lack bottom end without an enclosure. Plus they tend to suffer...
I think you need like a 10x switch on an amp? You would need to bandpass the mids or something Pioneer network mode or similar? I know the new...
I have ran the 6.5’s, but not the tweeters. They were very smooth and had good low mid bass. They were perfectly happy being high passed at 75 hz...
itscody
itscody
West Va
misfit138
    May 12, 2024
Brendon Jenness
    May 11, 2024
