Midbass Rattles Windows
Maybe a mount loose ?
I was thinking back to a problem I had one time with wind noise. Had one where the window had a lot of play in it. I could lay my hands flat on the glass and wiggle it all around. Came from the factory that way. Turned out the window just pushed down into slots that were supposed to hold the glass firm. Once I got it in good, no more wiggle and no more wind noise.
if you could some how place a speaker near the location it sits with the door panel on, without installing the door panel, and then playing some music you maybe able to recreate the problem, so you can pin point it and fix it with ease since the door panel wont be in the way hiding the problem. also when you lower your window it maybe stiffening the interior of the door to the point its eliminating the problem, and when rolled up then it allows for the door to flex more an for the noise to be created.
kicker06
Umm, I don't pay for food
kicker06
Atlanta & South Carolina
PowerNaudio
michigan born
    May 14, 2026
michigan born
    May 14, 2026
