Midbass options?
A EQ wont' mess with your signal that much unless it's broken. I agre with everyone else. On your seven band you'd have to increase 2 bands just to equal the change in 1, they cover a bigger range. The ENTIRE point of an EQ is for flexability, to quote squeek 7>4. If they caused you to a have a dip in those frequencies why didn't you just EQ it out, isnt' that what they are for?
couldnt get the same results with the arcs that i have been able to get with my SP4.
hours of testing obviously dont make up for the extensive catalog learned knowledge that you have.
If you you spoke with substance or some real 'hard' data , but no.
I've played with some of the finer analog units on the market , SP4/SP7 as well- the 'magical' difference you claim by simply adding the unit does not exist-period, so stock smoking the Zapco pole. There isn't even any difference between the opamps used between the units that would result to sound outside of the changes of the tuning itself- all an eq like that serves is as a fancy preamp with tone controls.
If you you spoke with substance or some real 'hard' data , but no.I've played with some of the finer analog units on the market , SP4/SP7 as well- the 'magical' difference you claim by simply adding the unit does not exist-period, so stock smoking the Zapco pole. There isn't even any difference between the opamps used between the units that would result to sound outside of the changes of the tuning itself- all an eq like that serves is as a fancy preamp with tone controls.
i too have played with the dxe, sx-sl, as well as other high end analog processing, so i do know what a good EQ is made of.
either way, it must be the fairy dust they use.
Lets get back to helping me with some midbass options. I didn't ask for opinions on any other EQ other than the Kenwood that I listed. I was wondering if it would give me enough control over everything to b happy, and plus it will mount n my extra DIN slot.
the original point was that you can get a better EQ for the money.
96MaxGLE
96MaxGLE
Greenville, NC
96MaxGLE
