metalhead needs a ported box design for a 12" Pioneer TS-W3003D4
that sub does have 2 spiders., mine took few weeks to get loud on around 400rms but yeah front slot port worked good for me, idk side ports.. i would stick to 36-38hz 1.5-1.6cf ad.. whats your gain at?
Ok. I am going to try 1.5 net with 36 tuning. What width does the 22w need to change to and what length of ports? At work right now so can’t check
How are you guys getting such a high volume?
I was the one that said 22x14x14 with 2 3x 15.5 ports and dowel bracing. I use the calcs on the12v and came up with about 1.6cf at 36.65hz.
OP added the 45s in all 4 corners and didn't make the box bigger to account for the space they take up. That's an extra .11cf of space, which drops the volume to 1.48389cf tuned to 38hz.
yeah u better check your cf subtract all bracing and sub disp.. if u still have 1.69 u could maybe add more wood to inside if u just trying to make box smaller and raise tuning.. u may need to play some bass on that sub to get it broke it..
u are right... idk what he's not hearing unless he made box bigger..
2RZ-FE
2RZ-FE
Dixon, Ca
2RZ-FE
