metalhead needs a ported box design for a 12" Pioneer TS-W3003D4
35hz, 36hz, 38hz. Make up your minds. You're right too many cooks in the kitchen...
Torres with these dimensions 14 x 22 x 14.5, .095 sub displacement and two 3x15.5 ports that gives me 1.69 net with a 34.84 tune. 36 if you believe the app is off by 2hz too low.
I will try all positions when this box is complete. Not much air was coming out of the ports for a loading wall to help. I am thinking something else was not right.
How do I check a sub if its ok not in a box a 9 volt?
its not that dude, its pure phase issues if you dont have the port close to a loading wall. It doesnt matter if there is air or not. You want the incident wave and reflected wave in correct phase with eachother or else you basically lose almost all your output.
Also try covering one port Could also be that the sub doesn't like a lot of port area.
Same port .6?
.2 less would be 1.49 which is close to the recommended size. Need to buy more mdf. Make a side panel and bring it in some
Going to see how this works first
Ignore the 6..
Notice how the recommend a small box for "tight" bass? 1.4 should be good. It's a high qes high mass woofer it's efficent downlow you can use a much smaller box and get the same extention
2RZ-FE
2RZ-FE
Dixon, Ca
2RZ-FE
