messed up amp?
Matador
-= StillBumping =-
sup guys, got a problem. i just got a cheap sub to play with it, but it's not working.
the speaker wires are new(12gauge), the RCA is fairly new too.
here's what i did so far, i checked the speaker wires coming out of the amp for any signal or anything with a DMM, and there's nothing, so i m guessing is teh amp. then i checked the RCA (not sure if i did it right, just + n - from RCA to + n - to DMM), n there seems to be no current there neither.
so it's prob between the RCA (hopefully this cuz cheaper) or the amp.
am i checkin the RCA right? i m prob gonna check the sub outputs from the hu but doubt it. how else can i check whether the amp is receivin or sending any signal?
i would appreciate any help, thanks. //content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif :banghead:
or connect wires to your sub , then tap them on a 9volt battery. if it pops then it works.
to find out how stable it is get a digital multimeter with an ohm setting and test the speaker leads to see if it is reading the ohm load the speaker is rated at.
take the amp to your local car audio shop and have them test it
cheap
this will end the idea if it is bad to not
to test the rca cables
take the cables and put your dmm and continuity it will beep if there is a solid connection
put the black lead on one center and the red on the other
repeat for the outside
Matador
-= StillBumping =-
Matador
Ca
mustang0969
