Mercedes-Benz 1999 ML 320 Bose Wiring New Head Unit
  • 1
Hello,
I have a Mercedes-Benz 1999 ML 320. It comes with a Bose Amplifier and Subwoofer. I took out the original tape player and replaced it with a double din Android Head Unit: https://goo.gl/XrV6Yp
For the speakers connection I used the RCA outputs from the new headunit instead of the direct wiring from the harness, because the direct output from the new headunit created a lot of noise and distortion (I'm assuming amp from new headunit to amp in car was too hot a signal).
I just have two questions:
Question 1
The subwoofer wiring diagram on the car shows four connections - instead of the regular 2 connections of positive (+) and negative (-).
I wouldn't know how to splice that to an RCA head to connect to the new headunit's subwoofer out RCA plug.
There is a good amount of bass in the car when I play music - does this mean the car's amplifier is automatically distributing bass to the subwoofer without me having to connect anything? If not, how can I connect it?
(I attached the car's wiring diagram as well as the headunit's wiring diagram for help).
Question 2
The person who initially installed the unit when I was out of the town, not sure he did a good job. Do you guys mind verifying the following and if I need to change anything?
1. Headunit ACC wire -> Connected to -> Car Ignition wire (Shouldn't this be connected to the Constant 12V?)
2. Headunit Amplifier Control wire -> Connected to -> Car Antenna Trigger wire (Do I need this connection at all if don't want to use the FM/AM? Or is this something for the amplifier?)
3. They connected both the "Ground" and "Brake Control" wires from the Headunit -> Connected to the same -> Car Ground wire (What is Brake Control? Do I really need this to be connected to anything? What purpose does it serve?)
4. Finally the Headunit's ILLUMINATION wire was left unused and the Car's ILLUMINATION wire is also unused. Shouldn't I connect them together? My new headunit's Panel light is always on. If I connect them will they turn on only when I turn the car's lights on?
Thank you guys so much for all your help
Nick
Excellent for good sound stage and imaging, don't expect it to move your mirrors or anything. Honestly with what you're trying to do just doing...
There is the 16pin connector in armrest of my old mercedes 2006 S350. Any possible way I can stream music from my phone wirelessly(Bluetooth) or...
Hi, I have a 2015 Mercedes W205 with the standard audio 20 system, which is terrible to be honest. In my W204 it was really good even though I...
No reason you can't get the sound you want with ported or passive radiator but if you have no ability to tune the mass of the passives you will...
Are you planning on reusing the power pack? If yes cut the wires at the top red arrow only. Connect your new radio harness to the translucent one...
nicolaselhani
nicolaselhani
New York, NY
nicolaselhani
    May 18, 2024
    May 18, 2024
