Memphis Mojo/HIGHS Wiring Help..
1000101
Kentucky
Ok, no naked sister pic, but it does get a bit more attention for my post..
I have a Memphis Belle Amp
RMS Power 4 Ohm Stereo Ch 1-4/Ch 5 (4 ohm Mono) 14.4V….......75 watts x4/300 watts x1
RMS Power 2 Ohm Stereo Ch 1-4/Ch 5 (2 ohm Mono) 14.4V………..115 watts x4/600 watts x1
RMS Power 4 Ohm Bridged Ch 1-4/Ch 5 (1 ohm Mono) 14.4V………230 watts x2/1100 watts x1
Input Sensitivity……..250mV-9V
Frequency Response +/- 1dB……..10Hz-50kHz/10Hz-650Hz
Dimensions 7.6" x 2.4" x……….25.8125"
Optional Remote Gain Control…….. MCRG
I want to run the amp this way
It should be sufficient enough to run the 2 15" mojos and then 2x 12" M3's. the mojo's have an rms rating around 1,000wtts and the M3 is 400 rms. so if I push 230wtts to each M3 and about 550 watts to each mojo. This should be just fine enough…right?
This sounds great and all, but I’d rather just run 2 Mojos and use the other channels for my mids/highs… any advice on how to wire this.. are there any component/mids/highs out there that can handle lots of power..
It seems like I can only run the amp as a 3channel or 5channel and I definetly want to run 2 Mojos at 550wtts each.. but the remaining 230wtts need to be for highs.. what do I do.. just turn the gain way down?
the bold part gets cut off from the title so no more attention for you... pics or ban?
You do not want to hook up the memphis mojos and the m3s to the sub ch on that amp, your going to want to have all matching subs, with matching sensitivity, and coils! It going to sound like ass that way bro!
I'd never do that, someone else gave me that as an option.. I just know that in that config, MINUS the two M3's, I want to run my Highs/Mids there instead. But 200+ watts is a lot how do i go about placing all of my speakers on the amp and what type do you reccomend?
Or cn i unbridge the 4 channels and run them normally but still get the 1100wtts at 1ohm for the 5th channel?
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
949
https://caraudiobargain.com/audio-apex-cab-22-car-amplifier-monoblock-2200-watts-rms/ Since these are back in stock they're really hard to beat...
969
And the most important thing you've learned in life up to this point is to get offended on behalf of other people on the internet in the attempt...
18
4K
So recently I bought a Memphis prx1000.1 and installed it to 2 rockfordfosgate r1s'. Both svc and 150rms 4ohm. I wired them to a 2ohm load to the...
Kentucky
    May 18, 2024
    May 16, 2024
