Ok, no ***** sister pic, but it does get a bit more attention for my post..
I have a Memphis Belle Amp
RMS Power 4 Ohm Stereo Ch 1-4/Ch 5 (4 ohm Mono) 14.4V….......75 watts x4/300 watts x1
RMS Power 2 Ohm Stereo Ch 1-4/Ch 5 (2 ohm Mono) 14.4V………..115 watts x4/600 watts x1
RMS Power 4 Ohm Bridged Ch 1-4/Ch 5 (1 ohm Mono) 14.4V………230 watts x2/1100 watts x1
Input Sensitivity……..250mV-9V
Frequency Response +/- 1dB……..10Hz-50kHz/10Hz-650Hz
Dimensions 7.6" x 2.4" x……….25.8125"
Optional Remote Gain Control…….. MCRG
I want to run the amp this way…
It should be sufficient enough to run the 2 15" mojos and then 2x 12" M3's. the mojo's have an rms rating around 1,000wtts and the M3 is 400 rms. so if I push 230wtts to each M3 and about 550 watts to each mojo. This should be just fine enough…right?
This sounds great and all, but I’d rather just run 2 Mojos and use the other channels for my mids/highs… any advice on how to wire this.. are there any component/mids/highs out there that can handle lots of power..
It seems like I can only run the amp as a 3channel or 5channel and I definetly want to run 2 Mojos at 550wtts each.. but the remaining 230wtts need to be for highs.. what do I do.. just turn the gain way down?
