memphis mojo 15d2 vs. jl3w7
good hard bass and really clear and ive got 1200watts rms
I guarantee you that the Hifonics Brutus in your signature WILL NOT deliver 1200 watts RMS unclipped at any frequencies you will be using it for!
So aside from being lucky to get 1,000 watts RMS @ 1 ohm, you have a slight problem with the way a 13w7 rates with its dual 1.5 ohm coils. Will your Brutus survive daily @ .75 ohms? Some run fine @ .5 ohms whereas others pop @ 1 ohm. I guess the subwoofer you choose depends on how lucky you feel:laugh:
Notice I said "unclipped". I watched a BXi 1608d start to clip @ 40 volts of output, or 800 watts RMS, on a 2 ohm load hooked directly to the subs! That is a tad bit less than the 1,100 watts RMS that amp is supposed to deliver at 2 ohms, but what more should one expect from a budget amp?
may be a buget amp but it puts out really good power
i think im gonna go with the mojo because of the cheaper price
my buddies got a 15" rockford t2 and has a hifonics amp hooked to it and has had no problems at all with the amp and it puts out the power that it says its supposed to.
may be a buget amp but it puts out really good poweri think im gonna go with the mojo because of the cheaper price
how do you know?
i had 2 mojo's it wont take more then 1500 true rms
but sounds **** good
u should be happy with either one
they will take 1500rms and up...I promise
and MOJO's arent that great of a sounding sub IMO....others may disagree, but the ones I have heard havent and specs point that out as well
if u had to choose out of these 2 for SQ....the w7
i had one of mine hooked up to a t15001bd(not sure if that is the exact name)
the sub could not handle more then half way up on the gain
and all the settings were done at the local audio store with their volt meter or what ever they use to set amps with
i had one of mine hooked up to a t15001bd(not sure if that is the exact name)the sub could not handle more then half way up on the gain
I promise a MOJO can take 1500 watts like a champ.... they might have had it in the wrong box or didnt know what they were doing
Pretty odd because I had my mojo's on a MCD4kw and they took it just fine for about 6 month's until the car died. The right box and proper settings on the amp will make a world of a difference.
Ive seen several setups with MOJOs taking anywhere from 4k-16k //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
jeepdriver001
jeepdriver001
Crystal lake, Il
jeepdriver001
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
